Fitting a double fun into a Toyota Corolla sr
Hello I've just purchased a 2005 Toyota Corolla sr and wanted to fit a double din and wondered if someone can point me in the direction of what I need or if there is a double din that would be a direct fit
Not  a conversion I have done, but if you search this and the Audio section you should find details of what others have done ok.
https://www.toyotaownersclub.com/forums/forum/19-audiovideoelectronics/
You will loose the mpg /ave part of the Toyota radio, but thats no great loss.
Have a look at the Car Audio online places like here, where they sell the Double din bezels, wiring adapters and steering column adapter.
http://www.caraudiodirect.co.uk/adapters?cat=1864
Check out rthe posts for DAB aerials as some have fitted a fin instead of the whip one and gained good reception.
Also consider replacing your front Speakers, easy enough, and they give a really good sound improvement, I used some Pioneers with separate tweeters up on the door/dash, though you may ready have them on your model  ?  Extra sound dampening around and behind the new Speakers also improves the bass.
