Yellow Spanner Light
Trafford99
I have seen similar posts to this, but none with same symptoms exactly.
I have a 2012 D4D yaris. It had a service around 4 months ago. Not long after, the yellow spanner light came on and stayed on. I reset it as described in these forums, only for it to come on again a few days later.
Having reset it several times,  I am now unsure if something else is wrong.
Today, having been on for 11 miles, I called for fuel. When I switched my ignition back on, the light went off.
Is the light solely for service indication or does it serve s dual function? Also, could it be something as simply as a dodgy sensor?
Thank you for any advice on this issue.
