1.4 4d Corolla 2005. Front Brake caliper carrier bracket?
Anyone know where I can get a new front passenger side brake caliper carrier bracket due to mine being damaged. Main dealer wants a ridiculous £187.55 for it, second hand seems rare as hens teeth, haven't as yet sourced a pattern part  maker for one they only seem to do rears.
Try your local breaker's yard or eBay.
Seems some new are around though you need to check which make of calipers you have, the name is usually stamped on the caliper body  eg  Lucas /TRW or Aisin, but you need to look hard.
When fitting best to use new bolts, only a £ or so for the correct hi tensile type from Toyota.
What do you mean by "damaged"?
