Vibrating Noise (2012 Auris)
D.Lynch2000
Hi how are yous all?
I own a Toyota Auris 1.4d-4d TR 2012 (129,000 odo),
I've bought the car second hand from a used dealership I've noticed that when in 5th gear usually when your about 60-70 mph she makes a loud vibrating noise , nearly like the engine is struggling.
its seems to be when you press the accelerator a bit more it makes the noise when you lay of the accelerator it stops, sound comes from mid area between the gear box and engine
if anyone can give me some guidance that would be great thanks
appreciate your time
Hi, from your explanation it’s a good idea to check clutch and flywheel, transmission fluid, and driveshafts, pretty much everything in the drivetrain. Just visual inspection for beginning, some test for worn clutch , noises on idle from the same area. Engine mounts too.
Good luck
