Avensis 2L 2007 model
Christopher71
I have an injector needing replaced. I ordered one but I got one for a 2006 2.2L
I was to get the car fixed tomorrow, would this one still work?
Welcome to Toyota Owners Club.
Moved to the Avensis club.
No the injectors do not share across engine sizes, they also vary by build date and you cannot mix different age injectors, for example injectors on 2.0 1AD built before 12/2007 are no longer serviced you can only get post 12/2007 injectors and they have to be fitted as a set not a mix of old and new.
I'm also assuming you have the later 1AD 2.0 with timing chain and not the earlier 1CD 2.0 with timing belt
The car is dated 03/2007 and has a timing chain.
Does that mean I’ll have to replace all 4?
If you are buying new or Denso refurbushed then yes otherwise find a Early 2007 2.0 1AD for a used one
