The car starts hard
Karlos777
Hello everybody,
I have Toyota Camry and since 1 week the car starts hard, I have to turn the key a few times to get it started.
Could someone help?
I'm guessing diesel? How do you turn key few times, do you mean crank it few times?
You need to update your user profile with correct car model/engine.
No, I have also Toyota 200, that's why I wrote 200 in my Profile but I have problem with Toyota Camry 2.4, gasoline, year  2003 and after I turn the key more times, the car starts
If  you  have any idea  I'd be pleased.
Do you want to say that you turn the key, it does not crank, then you do this few times until it starts to crank normally?
You need to explain the problem a bit better.
Does it make any sounds, what happens, how long do you crank if it cranks etc.
Yes, I turn the key few times until it starts to crank and then is to hear some clicking noise
Clicking sound means low Battery voltage, when was it last changed?
Have you measured the Battery voltage,  and by "starting hard" i guess you mean it's having troubles turning over the engine, until it starts?
Check the Battery voltage and replace if needed.
My Battery was changed 2 months ago. I think it must be ok, but I checked the Battery and the voltmeter reads less than 13 volts.
Is it normal?
