Vibrations
peppi
Hi.  I have a 2006 Avensis with 75,000 on the clock.  Had a replacement turbo charger fitted a while back and was told that turbo charger had been adjusted a little to cut in sooner.  Recently there has been a " fine " vibration as I accelerate which is getting worse.  It also occurs  if I put it into gear while stationary and slowly rev up as the clutch takes the load.  Any advice will be great fully received.
