Not starting
njekmat
My toyota yaris 1kr is not starting.fuel is coming the spark is there.it was Battery got low from ther e it has not start
Sent from my SWITCH using Tapatalk
Recharge or replace Battery and try again, it could be several things but it it was started previously just to move the car a few metres and turned off it could be that the engine is 'flooded' (spark plugs wet with fuel) if this is the case then after charging/replacing Battery start the car with the accelerator pedal flat to the floor until the car begins to splutter into life. Is it a manual transmission or mmt?
Look here:https://automotivecraze.com/how-to-jump-start-a-car/ . It helped me once
