Hi guys, I am located in South Africa. I own a Toyota Corolla 1.6 GLX 16V (bubble) and just recently it switch off if I break or rev hard.
What can this be?
Can you expand on your problem a little more...?
When you say  'it switch off ' do you mean  just  the engine suddenly cuts out or  the engine and everything stops including the electrics,  like the dashboard goes dead with no power .
What happens next,  does it restart straight away, as if a normal start up ?
Do you get the problem when driving along  and you switch or flash  your headlights on, or switch the air con or rear screen heater  on, if fitted
