Prius plus engine problem
Adam.hu
Hello Everyone!
 I have a Prius Plus and I'have been struggling with the next problem.
 The engine jerks and the igniton jingles.
No error code ind ECU system, but we made a live data monitoring test (enroute) and the computer signed
ignition problem in changing piston. Once piston 1 and then piston 4 then piston 2 etc. but not continously neverthless the engine jerked all on the test way.
What we did for fixing the problem:
 - EGR valve  pipe and cooling system cleaned
 - Repleaced spark plug and coil
 - Repleaced air mass sensor
 - Engine cooling water level ok
 - oil consuption 0,5liter(0,13gal)-1liter(0,26gal) / 15.000km (9500mi) so its ok
Has enyone have idea?
 Thanks Adam!
So the above oil consumption is in US gallons rather than Imperial. The equivalent in Imperial gallons is 1 litre/0.219 gallons.
I've heard of some Gen 3 Prius owners in the US (same powertrain in Prius+) ended up getting the ECU replaced due to issues with poor running.
