USB stick cutting out turning radio off
YarisOAP
I have had this USB stick for 4 years worked fine but now starting to turn
radio off after about 1 minute but sometimes goes all day with no probs
got Toyota to check it out at last service but came back all was well when they
checked the stick is a 16GB sandisk with 1200 songs on it do you think it's
the sandisk playing up or has anyone else had similar problem
Did you have any car updates done in the meantime, if yes, did it started shortly afterwards?
It was happening before the service if they did any updates don't know going to  buy another USB
and transfer the songs and see if it was the USB stick if not back to Toyota
Try splitting songs into folder, up to 199 songs per folder.
Its more than likely the format of the stick has become corrupted over time, it could also be the stick failing with read/right issues a incar environment can be harsh on device as they are turned on/off constantly
I will find out going to buy 32mb USB from Currys for £7.99 my son in law going to transfer my songs onto that as I don't have a laptop now only iPad and iPhone 6s +
The old USB stick was faulty after 5 years the new one works fine now
No surprise really thay have a limited rear/write cycles - the tech has moved on the last few years so this one should give a bit better service
