Reverse camera
Reverse camera
Hi have rav4 fitted with aftermarket reverse camera kit working through original head unit. It only works if i put the car in reverse after start up and beat the radio to appear on the screen (about 4 seconds (Toyota symbol  first)  it will continue to work shifting in and out of reverse until the ignition is turned off,then it will only work again next time if I put it in reverse after start up before the radio appear on the screan again.....Has anyone seen this problem before?  Thanks
Welcome to Toyota Owners Club.
Moved to the Rav4 club.
