Corolla E12 : Orginal radio push buttons don't work anymore
I have a Corolla E12 with a original radio type : 58816
the have since a while a problem with the push buttons.
Only the : Mute, Power, Tune/Enter works.
steering wheel buttons is working fine.
What can be the problem ?
If its just some of the buttons /functions that are faulty, it must be within the head unit itself.
If you or someone is handy, you could take it out, strip it down and clean/inspect the faulty switches, however if its anything more or needing parts its going to be a long and possibly expensive job and probably cheaper to either fit a new head unit or get a second hand one,
If you search this forum, lots of posts about putting in a new after market single or double Din head units or you could check out the Toyota Buy /Sell forum or eBay for the used original units that folk removed when they upgraded their head units.
https://www.toyotaownersclub.com/forums/forum/23-for-sale/page/2/
  • 3 months later...
On 12/3/2019 at 4:44 PM, Londemanmp said:
did you find out what is the problem & solution for it, I have started to have same issue.
  • 4 months later...
Hi, weird thing happened...
After a month, radio was disconnected from car, i ordered wrong adapter cables for new aftermarket radio so i deicided to put back original radio back till new adapter cables arrive. So, I connected original radio to car, and everything works fine, all buttons are working now. I didn't serviced radio or dissaseble it.
Possibly being totally disconnected allowed it to do a  true "cold" start, which reset its switch logic circuitry /software ?
So are you going to fit the new radio ?  Could always sell your old Toyota radio in the forums For Sale section etc.
