Dpf regen
Mikeb74
Tspirit 1.4 d4d. 78k on the clock. As seen on the mechanics computer, dpf is blocked with soot. I commute 100 miles round trip, most of that on the M4. I've tried several 30 min drives in 4th doing 3000rpm and still the dpf isn't regenerating. I do small journeys around town in between work obviously yet would his still effect the dpf?
Are there any other fault codes showing along with the DPF fault code
