Wheel alignment
mflorant
Hi, it's me again (2009 T27 Petrol 2.0)
I've been to wheel alignment because the car pulled to the right (the steering wheel also steered to the right), but when I set off or slowly going or braking, the steering wheel still turns right.
What could be the reason?
Regards
Was it pulling before you had it aligned?
Is it pulled to the same direction before and after the aligned?
Had you replaced the tyres recently?
It was pulling to the right before alignment, after alignment it is less pulling.
Same direction
Haven't changed tyres
Thank you, regards
You could try and swap the wheels on the front . Assuming the tyres are not directional. Check first.
I had similar problems on a few of my cars and I had managed to cure the pulling problem by swapping the wheels. No harm by trying.
