Need help
Kiran Zaman
Hi everyone.. im having few minor troubles with aygo 2007 model.
1. It trembles very badly when engine starts, when in neutral and in first 2 gears
2. It's air bag sign keeps blinking
3. It doesn't have fog lights space
4.
(1) has the car been serviced to toyota standards i.e. plugs been changed
(2) for the airbag issue
disconnect the Battery for 20 minutes then
unplug the connectors under the front seats
and then reconnect then reconnect the Battery
I've tried these. The mechanic says maybe clutch plates need replacement
How many miles has it done?
The early Aygo’s, which yours is, was originally fitted with a clutch plate that wore out shortly after 26,000 miles (some lasted a bit longer). A larger clutch plate from a Yaris solved the problem. But clutches still wear out, some quicker then others depending on their use. So I suppose your car could be at the end of its second clutch.  But whether a worn clutch plate could cause juddering when in neutral, I unsure, but maybe.
The airbag light blinking must be a separate issue, I have no idea why it’s blinking.
What do you mean by “it doesn’t have fog light space”. Is that front fog lights or rear fog light?
Sur thank you for replying..
It doesn't have any space for fog lights on both front and rear bumper
No dedicated slot for fog lights
