Difficulty starting
peter.ling24@gmail.com
Hi all,
After several months of trying to find out why my car has difficulty starting, I have found the cause.
I would like to thank you all for the suggestions which I followed on to determining the cause of the symptoms I had with the car.
The car now runs like new. It's remarkable how much the car drives so much better and responsive.
The cause:
2 bad injectors. The other 2 were borderline performance, so all 4 were changed with reconditioned Denso injectors.
I didn't consult Mr T, as I knew the cost would be astronomical! For what they would have charged, it wouldn't have been worth it exceeding the value of a 2005 car.
One injector was not holding pressure and the other was atomising diesel too late,  at a higher pressure. The other two could have been replaced, but not recommended.
I am so pleased it was done. It has certainly greatly increased my confidence in the old girl.
As much as I try to do what I can with regard to maintenance, there comes a time when you have to let the chosen professionals do their thing.
The outcome of this venture is that I have found a garage and diesel specialist who didn't charge an arm and a leg and has years of experience with diesel injectors.
Again, thanks to all who have contributed to my requests for help in the past.
Peter
