Altered pipe (Poss unburnt fuel return?)
Dodge F
Hi
Could anyone please advise ont his modification?
We are looking at buying a Toyota Avensis D4D but on the right hand end of the top of the engine the pipe in the picture (A) has been disconnected and sealed with the item at (B).  is this a toyota recall issue or a bodge ?? I have no idea but concerns me that seller has all paperwork EXCEPT for this mod and states does not know what it is?   Any advise most gratefully received.
Thanks Dodge
lmao, run very fast in the other direction from this car, that's a bodge and a half (note the cracked/chewed casting on the high pressure pump around the banjo)
What reg is this ? its the high pressure feed to the fifth injector (injector for the dpf) than has been bypassed it may have had the dpf deleted what is illegal
Moved to the Avensis club.
Bargepoles spring to mind!
