Hello guys. I'm having a problem with my Toyota Corolla T-Sport 192bhp.
When my car is stationary the coolant temperature is normal but when I drive,  the coolant temperature drops dramaticaly.
What causes this problem?
Quite likely a failed open thermostat, so the coolant is always circulating through the radiator.
Thank you. I Will replace the thermostat.
I replace the termostat. Problem solved.
