2008 Yaris SR leaking rear lights
Gazmac
Hi
I’ve bought a 1.8L Yaris Sr, it’s a superb little car. The only problem is both rear light clusters are letting water into the boot. It sounds like this is a known issue for a Yaris, I have ordered some new gaskets but they do not fit the SR model I’ve also ordered new light clusters from europart but they are not like for like. Has anyone got advice on how I can stop the leak or where I can get parts from.
Cheers Gaz.
French or Jap built ? 3 or 5 door ? Were the seals from a main stealer ?
Edit, its a jap built car the part number for the seals are...............
81554-52570 RH Gasket
81564-52500 LH Gasket
parts can be a bit of a pain, you must make sure it's for a Jap (JPP) built yaris - you can have problems with ordering brake parts too
Wow thanks for the reply that was ultra rapid, I have the 3dr model. The parts I ordered were from Toyota on eBay, do know of any good sites I could get parts from.
Did they confirm the parts by reg ? if so what was supplied ??
There are not that many places online but you could try parts-king on the forum (best to drop him a pm
https://www.toyotaownersclub.com/forums/forum/120-lindop-toyota-parts-king/
If you want the full details on your car drop me a PM with your VIN
Yeah they provided parts 81564-52260, euro parts were the same for the light clusters again they were for a standard Yaris.
81564-52260 Comes back as a mk1 yaris 2001 - 2005 JPP built so that explains why they don't fit
