Yaris 2000 Heat A/C control panel bulb
Serkoulik
Hi to everyone.
I have a Yaris 2000 model and I would like to know what is the exact bulb type of the Heat, A/C regulator control panel. The bulbs that light up the indicators so you can see the switch and the thermometer of the panel at night.
I have attached also a photo. I need the exact bulb type that is behind the below switches in the photo.
Thank you!
French or jap built ? what country are you in/from ?
84999-06010 - 12v 1.8w are the only bulbs listed (x2)
swap them for leds if you can find the correct type
Edit. See this listing for reference https://www.ebay.co.uk/itm/TOYOTA-YARIS-2004-LHD-A-C-AIR-CON-HEATER-CONTROL-PANEL-SWITCH-758294/264288435907?epid=654899938&hash=item3d88d17ec3%3Ag%3ACsQAAOSwYelbl2gZ&fits=Car+Make%3AToyota|Model%3AYaris%2FVitz|Cars+Year%3A2001
It is Jap built.
I am from Greece.
What about these? They seem to be similar but Yaris is not listed as a compatible car.
https://www.ebay.com/itm/10x-T4-7-T5-Neo-Wedge-LED-Bulb-Dash-Climate-Control-Instrument-Base-Light-Lamp/263596797322?epid=4003587127&_trkparms=ispr%3D1&hash=item3d5f97ed8a:g:ElgAAOSwu4hayxhl&enc=AQAEAAACQBPxNw%2BVj6nta7CKEs3N0qU0b3SanvZ1I0T2WnT1b2fPQI4L7gT50Ki7cL1Ur6k6eHm7d7BP%2B8%2BKMVCKJrNBSOhnXtu27zMvKLGGyj6vUF%2F5ECxh8UpKScF8KcoNLPBtwV9DnzDlgyuCO%2F5%2FuOSSMPRrc8EqeJGy1AFCRbz5enwEVR9zUHMkAqV9jW5YNBLinhtzpc6hyDAeCqL4u60BcrxreF7eB4g4%2FAnkn%2BVTeFBD4ensiX3rEtTfXj%2FdpIE%2FMgxIa7t4IWQb88htHzCGPjgEmCYlR%2FZ%2FCUSWWtcaOnqzkKOBca1H%2BbETfPCpvcjK1umiekRuzzkP8Vq7xBatDBFHcL9J%2BSvchDiV67vlV70az0WIu28%2B8Tgytl%2BrXhECBtvVTorZx%2BBJcz0agORYgUeCA92O6TBaRUSZyf8dbadZ0Qd1EUYodkPAooYo%2F3uDf3YvkhoLw3hPatWr%2BVqYnTXlVCY0Cl701sSpWTJ1BzFCS01Tz9EYMuvM5j4A3%2FFzGkgaIsx6KvfAvYJbQHkY%2FlAl7i5zXz4p5JEpUB%2BDpp1HAlS%2Bi27JQQ95E49rPu2EAN%2ByxuniSuuZuto6EIQtprWMVS4fIGCuWOAwmj5jt6FyKkSn8LvGCM7AtDF%2BXEfEByjL2DLJlwkIfXbpEBCUD1kjOTSjDY6RX1YcksDXeeRPeqRvYUexEaVf6t5GOI2FOx2fWJMaoJ7yakDTHjiXYDhrKTqIatwH624OMHB4Rvu7eXVQR7UneqRhkIKHOyujwQ%3D%3D&checksum=26359679732221c55da2d98347debffb7ab7db93c8d5&enc=AQAEAAACQBPxNw%2BVj6nta7CKEs3N0qU0b3SanvZ1I0T2WnT1b2fPQI4L7gT50Ki7cL1Ur6k6eHm7d7BP%2B8%2BKMVCKJrNBSOhnXtu27zMvKLGGyj6vUF%2F5ECxh8UpKScF8KcoNLPBtwV9DnzDlgyuCO%2F5%2FuOSSMPRrc8EqeJGy1AFCRbz5enwEVR9zUHMkAqV9jW5YNBLinhtzpc6hyDAeCqL4u60BcrxreF7eB4g4%2FAnkn%2BVTeFBD4ensiX3rEtTfXj%2FdpIE%2FMgxIa7t4IWQb88htHzCGPjgEmCYlR%2FZ%2FCUSWWtcaOnqzkKOBca1H%2BbETfPCpvcjK1umiekRuzzkP8Vq7xBatDBFHcL9J%2BSvchDiV67vlV70az0WIu28%2B8Tgytl%2BrXhECBtvVTorZx%2BBJcz0agORYgUeCA92O6TBaRUSZyf8dbadZ0Qd1EUYodkPAooYo%2F3uDf3YvkhoLw3hPatWr%2BVqYnTXlVCY0Cl701sSpWTJ1BzFCS01Tz9EYMuvM5j4A3%2FFzGkgaIsx6KvfAvYJbQHkY%2FlAl7i5zXz4p5JEpUB%2BDpp1HAlS%2Bi27JQQ95E49rPu2EAN%2ByxuniSuuZuto6EIQtprWMVS4fIGCuWOAwmj5jt6FyKkSn8LvGCM7AtDF%2BXEfEByjL2DLJlwkIfXbpEBCUD1kjOTSjDY6RX1YcksDXeeRPeqRvYUexEaVf6t5GOI2FOx2fWJMaoJ7yakDTHjiXYDhrKTqIatwH624OMHB4Rvu7eXVQR7UneqRhkIKHOyujwQ%3D%3D&checksum=26359679732221c55da2d98347debffb7ab7db93c8d5
Remove one from the car and measure it, led wise something around 0.2w may be better
not 100% sure but most Toyota's take a T3 - 8mm or T4 - 10mm
This is a pic of the oem bulb
