Fan belt & wipers
Georgina74
Hi. I'm looking to cross match a fan belt and all wipers in my 2000 3L 7 seater G spec L. My ex used to order via Toyota dealership but I haven't got time ne to wait 3 weeks. Any ideas on part numbers or stockists? I live in Monmouthshire South Wales. Tia
The auxillary belt and the wipers should all be found on the likes of eBay and/or EuroCarParts et al.
That's where I go for those parts for my Estima.
These front wipers should fit your Estima..rear one is available too.
https://www.ebay.co.uk/itm/TOYOTA-PREVIA-2000-ON-front-windscreen-WIPER-BLADES-2818-TWIN-PACK/112435552
Thank you! Link for wipers is great!
It's cross referencing belt I'm having trouble with at the moment ... keep getting offered ones that fit but are a 3 groove in preference to 5 🤔
I bought a spare belt 2 or 3 years ago (just as a precaution..haven't needed to replace it yet)
I'm sure I bought it from an eBay supplier....it's a Continental 5 groove drive belt...6PK 1033/38. No. 202-44-0945..you should be able to track one down I'm sure.
I assume you have the V6 1MZ-FE engine..?.
IIRC there are two belts...fan/Alternator which is th 6PK ref...and a power steering belt which is a 4PK ref..the 6PK has 6 ribs and the 4PK has 4 ribs.
Thanks loads. Mine snapped last night so I'm currently stuck! It's not the power steering belt thankfully but I'm having difficulty with local suppliers identifying the right belt for me. I have a camry belt being sent this afternoon but I'm not convinced it will be the right one as I've never had parts cross matched from a camry before... I'll take a look now at your suggestion and will probably buy a spare as the belt has gone twice in 3 years!
Yes I'm the 3L V6 engine.
Thanks again for your help xx
No problem...and it's highly likely the Camry belt will be fine..same engine I think.
Many parts are common with the Lexus RX300 SUV  too...same engine.
Eurocarparts also stock the belt you want..in fact they stock both belts. 6PK and 4PK
Good luck
