Parcel shelf plastic clip
ggyy
Hi All, I am looking for a plastic pivot clip for the edge of the parcel shelf (drivers side) looks like it's not a sellable item and u have too buy the entire parcel shelf,  just wondering if anyone has run into this issue and found a source, , I have tried a load of breakers yards but they want to sell the entire shelf also,
Tks in advance
You can go to japan-parts.eu and see if it sells as a part, which i doubt.
2 piece epoxy is your friend, dries clear, very strong bond, and dries slowly, so you have plenty time to adjust it. Some general clip you buy at a store could also work.
These clips are usually sold on aliexpress and eBay, so worth checking there, i see them being sold in pair for 2-3 GBP.
Many Tks for the Reply I will check out  and fingers crossed ,
pic as follows to explain issue
Shurely a bit of aluminium sheet, the size of a matchbox, with one big hole for the pivot and two small ones to take a couple of small fixing bolts (or pop rivets)? You've probably got something suitable in your garage. Or a mending plate, perhaps?
The clip is part of the shelf, a used shelf is £40-60, 64330-02441 is the common one
