im just wondering if anyone has changed out the drum brakes for discs on 2005 corolla
Not aware the 2005 Corolla had drum brakes or were the Irish models that different ?
Think you  might be refering to the rear disc and drum combined unit , where the drum part is just used for the handbrake  .. ?
Seems the US models had just drums on the rears, so maybe yours is that type ?
Not seen mention of such a conversion, though even if it was possible without replacing the whole costly hub , would there be that much of an improvement as most of the braking force is on the fronts, also no idea if it would affect the ABS unit /pressures etc if fitted ?
If yours are rear drums might be worth looking on the US Toyota forums to see if anyone there has done such a conversion,
Ireland gets all sorts of strange cars and specs one what springs to mind is a Nissan Versa (Tiilda) saloon (sedan)
The vin will be able to tell you where the car was made
i will have a look to see what i can find, tbh drums are fine on a 1.6, discs are over kill - upgrading the fronts may be a better idea
By the time you are done swapping out the rear beam and replacing parts you will be into 3-500 euro
Just had a look since the 70's there have been 30+ variants of the Corolla then you have all the different models as well
If you can PM me your vin I can find the spec of your car
