Hello all, I've a 2007 corolla diesel and gonna fit a towbar to it, does anyone know the thread size which is predrilled in chassis?
I'd suggest that the supplier of your towbar will send the correct bolts.
Thanks Richard.  Need to run a tap through first because of rust and bolts not marked with size
At a guess I’d say the thread will be 10mm, possibility 12.  Take a bolt from somewhere else or the car and try it for size.  Maybe take one bolt from the top engine mounting for instance.
Thanks stavino. Hope to start it tomorrow so will try that
