Yaris Estore app download
Superjohn
I have recently bought a second hand Yaris and I am trying to download the Estore app in order to update the Touch2 system.
When I download from myToyota I only get a file called swdl.iso rather than the zip containing several files that I would expect. The file doesn’t work when plugged into the car. I have tried various devices and browsers and they all give the same result.
Any ideas out there?
Thanks in advance
JC
Do you have the sat nav ? you only get the connected services the sat nav
Updates are done via USB the stick has to be formatted correctly
I have satnav and the USB is FAT32 formatted.
The problem seems to be with the files downloading from the App Store.
I have put a post on the Toyota.co.uk blog, I’ll see if they come up with anything.
TBH the only useful thing I could update is the maps and that looks a bit too expensive. The only inaccuracies I have noticed on my current maps are with a few speed limits. I might just turn them off and do it the old way instead!
I take you are going into the service menu to do the update ?
Make sure nothing is plugged in to the usb, turn the car on, go into the service menu, go into service information then update, insert the usb stick
