Instrument Cluster
DRC58
Hi Guys. The L/H Indicator light on my instrument cluster has stopped working. I know the Indicator still works as I can hear it. Is there a way to replace the bulb rather than go to Toyota to get it sorted.
Any advise would be gratefully received.
Regards DaveC
This problem isn't unknown...
The lights are actually LED's rather than bulbs and require the use of some delicate soldering skills to replace as they are what are termed SMD (surface mount devices). Although the parts themselves cost buttons from electronic suppliers, a dealer would not repair this to component level and would fit a whole new panel.
There should be some threads around here showing this...
There's a thread about fixing it here:
As above, the most cost effective way to fix it is to solder in a new LED or find someone who can.
Alternatively as long as the audible click still works it is not an MOT failure and you can just live with it if you wish.
Hey guys. Thanks for the info. As i can hear the indicator working i think i will leave it for now.
