Master brake cylinder
Morten Taraldsen
Have been tryin to bleed brakes with no luck. How can i check if master brake sylinder is working ok. Open to all tips on brakes. Sincerly Frode Børresen
To bleed the brakes successfully, I find I had to use a pressure bleeding kit - Gunson Eezibleed available in the UK. Also with the correct car diagnostics that support the function, like Toyota Techstream, the ABS is also part of the bleeding process.
You must have a late registered car, because here in the UK at least, the Avensis was ceased back in 2018. The new Camry and Corolla have effectively replaced the Avensis.
what year avensis ? 2002 ? 2012 ?
i would use a vacuum based bleeder as it will pull the air out of the ABS pump if its still sucking air you either have a bad hose/joint/wheel cylinder/caliper or the master cylinder is bad
depending on the year and if its manual the clutch is fed off the same reservoir  if that is letting past you will lose fluid and it may draw air in
What was the original issue ?
