2010 Auris front brake caliper
SR-Manuel
Do the front caliper pistons on a 2010 Auris just push back in or do they need to turned and pushed?
Also, anyone know the torque settings for the slide pins and and carrier bolts?
From the documentation i got, it should be pushed back.
Torque below.
They simply push back.....but hybrid drivers take note.....keep the keys well away from the car before working on the brakes. If you approach the car with the keys in your pocket, the brakes energise, you can hear it.   SO KEEP THE KEYS AWAY.
