fues 10amp
cooks
Just bought a yaris 57 plate noticed the fuse under the glove  blox keeps blowing for the rear lights and heating instruments and fog lights..
any suggestions
what number/location is the fuse as they are on different circuits
Rear Lights - do the side lights work,do the numberplate lights work
Heater controls - do you just mean the backlight (illumination)
Fog lights - does it blow as you turn the stalk ? Are they goldfish bowls (full of water)
Edit. Do the interior lights work ??? do you have a switch that dims the dashboard lights ??
The rear lights and fog lights go as well as the heater illumination lights interior lights work and i have a switch that dims the dashboard lights.
I am not sure if it blows wen you turn the stalk. It also has parking sensors on the rear which have a single tone.
What is the position of the fuse in the fuse box that blows ?
do the parking sensors beep or is it a solid tone ?
Strange. I posted a reply yesterday that has become invisible. I suggested that, if they are aftermarket parking sensors, that's where I would b checking initially.
It's a bit of an odd one, the only item that links them is all control side ground switching (stalk) and/or Body ecu (BCM) the 3 circuits are otherwise seprately fused
if its aftermarket parking sensors it could be back feeding the BCM
or may be its just 3 separate issues of blown bulbs
they are after market sensors and found a cut wire i believe that was shorting the and blowing the fuse.
