Indicator Flasher Relay for 2005 Corolla Verso 1.8
My indicators just stopped working, but the hazards still work.
I've checked all the fuses, and now want to check the flasher relay, but I can't find it.
Does anyone know where it is?
Also, do the hazards actually have a separate flasher from the indicators? (I assume so, but if not, then I'm not so interested in the flasher relay)
Cheers,
Yato
Found it. I took out the instrument cluster, and found it on far right hand side under RHS air vent.
Denso flasher 81980-05040.
Taking that out stops the hazards working, so not sure it's the right one. Is there a separate flasher amywhere?
I've also taken the stalk apart and checked the contacts open/close when I move it.
Double-checked the fuses, and a 7.5 behind the glove compartment had blown. Fixed.
