tailgate will not open yaris
mike54
has anyone had similar problem 2003 yaris tailgate refuses to open tried keyfob manual unlock still will not open ???????
I have a 2004 yaris and sometimes my boot would not open i just pressed open button twice as it has deadlocks if you press lock twice. Hope this is your solution .
Is there an emergency release from inside the car?  If not, there ought to be.
Had them on other cars we've owned.
Mick.
I have had this two years running during an annual trip away. First time it happened I swapped to my other key. Next time it happened I opened the tailgate from inside by removing the carpet trim, held on by press studs and worked the lock from there. I took the lock apart, cleaned off the old hardened grease and relubricated it with spray grease. Now it works fine.
