Estima Hybrid Auxiliary battery
2 hours ago, ColinCodreanu said:
Can someone tell me where the 12v battery is placed in the car?
In the rear passenger side in the left rear wheel arch area - behind the panel where the jack is - it is under the jack.  Sorry I don't have any pictures. Remove the panel and you can't miss it.
Does anyone have a link for the battery that we have to buy?
I don't have a link but if you search the web for part number 28800-28071, you will find it.  Do bear in mind the warning from @flash22 "You need to replace it with the same battery type dont cheap out - be aware it's £200-230".
On 3/31/2022 at 11:33 AM, ColinCodreanu said:
We have just bought a Toyota Estima hybrid from 2007 and we need to change the battery.
Can someone tell me where the 12v battery is placed in the car? Maybe you can send me some pictures as well.
Thank you very much!
Just now, David Stevenson said:
a Bosch 005/005L Bosch Heavy Duty Car Battery S4024 12V 60Ah 4 Yr Wty  At £66 its worth a try. .
2 years on and its working fine
  • 5 months later...
Hi there wonder if anyone could help me I have just purchased a 2009 toyota estima 2.4 hybrid and have noticed an orange triangle and the words check hybrid system however I noticed the auxiliary Battery has been replaced with a ordinary batter and not a Panasonic or yuassa temperature sensor Battery could this cause any problems to the car or have any correlation with the light on the dash
Well thats the first thing the garage is going to do fit correct Battery.
