caldina engine Timing problem
Hi all
i have changed my timing belt and now it cranks over but will not start
the timing marks all line up but I don’t know what to do next
What engine has your Caldina?
Was it running well before - did the belt snap?
Check out all the You Tubes showing Toyota belt swaps/re timing.
Cheers
2sav
Hi 2sav
3S-GTE dohc 16-valve 2.0-liter Turbo
i changed the tensioner and belt because it was noisy, it was running Fine five weeks earlier But now all the timing lines up but will not start
