2007 Yaris SR - Door Unlocking Issue
lhc
Hi all, hope you're well.
I've an issue with my car being unable to unlock fully, and I was hoping you'd be able to help.
When I try to unlock my car with the fob, my doors and the boot unlock as they should, with the exception of my driver-side door. When it fails to unlock, my car cycles through the locks a few times before locking all the doors again.
I can't unlock the driver side door with the key - it only turns towards the locked position. When I try to unlock it with the spinner above the handle from inside, I'm able to rotate it towards the unlocked position, but it snaps back to locked immediately. There's a little bit of resistance when I do this. I suspect it's the cable or actuator, but I'm not certain.
It's also fixed itself as of 3 hours after I noticed it, after I drove to work.
I'd greatly appreciate any assistance you might be able to provide.
Its cold and damp so either wiring related or the solenoid is acting up, there is a chance that you have some water ingress into the locking module (drivers side kick panel)
