T25 2.2 diesel oil change torque values
Andyvtr
Hi all,
I'm soon to be undertaking an oil & filter change on a T25 Avensis 2.2 diesel with the 110kw 2AD-FTV engine.
Does anyone know the torque values for the; oil filter cap, oil filter drain plug and sump drain plug please?
Thank you
Kr, Andy
Update: The mann oil filter I purchased quoted the oil filter cap and filter drain plug torque settings of 25Nm & 12.5Nm respectively.
So just the oil pan / sump plug torque valve I'm seeking now...
You don't need to worry about the sump plug torque.  Just pull it up tight with your spanner.
