Bypass oil cooler 2008 Toyota Yaris
vyrus0139
Can I bypass the oil cooler on my automatic 2008 Toyota Yaris? Please let me know what details you would require to help answer this question. Thanks.
Why by pass the oil cooler? Maybe you live where it’s very cold.
In a word No, it's there for a reason - if its leaking in between the block and the cooler replace the gasket(s)/O-Rings or is the external type with pipe work (2nz-fe, etc)
Its there for a reason, delete it and you risk destroying your engine.
