Hello,
I have Corolla Verso 2007, D-4D 2.2 100kW. The car has 380.000km.
It seems I have a problem with ventilator(?) for cooling/heating ventilation for cabine.
The symptoms are that air flow is very low. Sometimes the power increaes but just temporary. And the problem is with cooling also with heating so I dont suppose it is a problem of clim gas.
Also yesterday, I had no air flow at all. Key off / on didnt solve it. But when I off thermal comfort panel and on again, it was OK.
I suppose there is problem with ventilator which I guess distribute the air inside the vehicle whatever the air is cold or hot.
But I have no idea where could be this ventilator located.
Could you advice me? Thank you, Martin
First thing to check is the cabin air / pollen filter, on a standard Corolla its located behind the glove box , just above the fan.
If its not been changed for a long time it will probably be very dirty /blocked.
If thats ok, I would suspect a problem with the blower fans resistor module, however, again on the standard Corolla, its location can depend on if you have a manual or automatic A/C.
Could be other causes, but would have the above checked out first.
