I recently bought a CHR with Touch 2.  I want to upgrade it to Touch 2 and go.  The dealer is quoting me £900 to install, surely the software just needs activating?
It's not a software change, It's a physical add on module or replacement stereo
It's easy enough to install you may be able to find a used module for £250-£350
this is the European touch 2 (plus) upgrade - if anything it shows how to take it apart
https://www.toyota-tech.eu/aimuploads/7ed1a5b8-4289-4dfc-b7e7-3b490de779e7/Toyota_C_HR_Touch_2_with_Go_RHD_PZ490_00334_AIM_003_947_3.pdf
I will have a look for some part numbers
Hi, I bought for wife's Yaris from e bay, £240, complete with Sat Nav aerial and connectors. I fitted it myself, (you might need adapter plate). Then on My Toyota register it.( should get fitting instructions also).. Fitting was easy enough, but I don't know about CHR.. By the way I was quoted £800, so a good saving.
