radio system
oisin2222
hi I have a 2014 Toyota auris 1.4 diesel aura model it has the button radio with the standard blue screen radio I want to try upgrade this radio to the bigger screen which comes on the luna model can I do so with this car thanks
In a word yes, not sure on the specs of the cars over there TBH
edit. there are 2 versions.(Numbers below are examples ONLY)
upto 2015. 86140-02290 or 86140 -02030
2015 onwards.  86140-02360 or 86140-02370 (dab radio)
Hi this is a pic below of the inside of my car would you be able to show me what touchscreen radio I can put into it thanks
You already have an answer from flash.
If you want a Toyota radio, then ask Toyota for the most accurate info.
If you want 3rd party, then check yourself on Aliexpress, eBay and so on, there are plenty of aftermarket radios, most require you to fit some adapters, they usually work with steering wheel controls, but you might loose some car functionality. You should ask the sellers for more info.
Use search on the forum, there have been similar topics in the past.
if you cut and past the numbers above into eBay or google you will see the 2 types for the mk2 auris
If you pm me your vin i maybe able to give you the exact part number
