front off side side light gone and what is this other light?
ziauris
My front off-side side-light has gone (Auris 2017 petrol), looks like a right pain to replace with the water pump in the way. Am I right in thinking that the side-light bulb is the one circled in red in the photographs below? Does anyone know what the bulb circled in green is??
Will I have to remove the plastic circled in yellow that is held in with clips on the top of the car bonnet to access the bulbs?
It's the one circled in green, from the back it's just the tiny all white connector. Red one is high beam.
To remove the side lights, you dont need to remove any of that plastic. Just get your hand there, it's 1/4 of a turn i think counter clockwise.
Take it out, replace, reinstall (if you will be putting led's, then turn it on before reinstalling to check if the polarity is correct).
It's a few minutes job.
i've never had this year of auris but could it be a park light for use whilst parking on the road at night, my thinking is small bulb should take less power and wont drain the Battery
thanks for the tip regarding the LED bulb! It took around 15 mins, hand to take 2 of the the plastic clips as it was very fiddly to do it successfully.
