Bluetooth Adapter for Toyota Avensis Verso
MarkMaas
Hi I'm looking for a bluetooth adapter for my Avensis Verso (2003) with Radio type 86120-44080. The Yatour models compatible via TOY1 or TOY2 do both not mention this radio type. Any suggestions?
Its more commonly known as 58808 is made by Matsushi-ta (Panasonic) and uses the 5+7 large plug for the changer
Connects2 CTATYBT001
I think you are asking what the socket looks like so you order the correct cable for the interface.
The earlier stereos had what they call type 2 or 5+7 socket, while the later units have type 1 or 6+6 sockets. It is always best to visually check the socket at the rear, especially if you are not sure.
I use the Wefa Bluetooth/USB adapter and works brilliantly for phone calls, music, and satnav directions, plus I can give commands to ask for new directions.
Also I have bought other adapters previous to the current Wefa adapter I am using, and even though my car/stereo model (W53828) was not listed, they all worked fine!
Here my experiences -
Also my how to which applies to most models -
Hopefully you can find what you are looking for in your particular market, but if anyone is UK based the Wefa is one to consider - https://www.ebay.co.uk/itm/Avensis-Music-Streaming-Bluetooth-Telephone-Charger-SD-AUX-CD-Digital-Module-5-7/132686665201?hash=item1ee4bdd5f1:g:dEMAAOSwjRtbOgEw
https://www.ebay.co.uk/itm/For-Auris-Music-Streaming-Bluetooth-Telephone-SD-AUX-CD-Digital-Module-6-6/142850621903?hash=item21428f81cf:g:qMEAAOSwnEtbOQW-
They are the same unit for any car and for each of the type 1 or 2 socket. The only issue could be those with separate nav unit or CD changer.
