can you fit facelift rear lights to prefacelift?
Auris James
I have a pre facelift 2015 Auris and wondered if the facelift rear light would fit? I prefer that all 4 sections are lit at night as gives better visibility.
Has anyone swapped and is it possible?
James.
  • 8 months later...
Hi James
did you manage to change your rear light to the facelift
if you did I would like to do it to my Auris 2014
any information would be helpful
43 minutes ago, Mnaeem said:
Hi James
Never investigated further and so haven't done it. If you can find a facelift set, before buying see if the size, fixing and wiring plug is the same.
If you do go ahead let me know how it goes as lights from breaker was £120
James.:thumbsup:
you can always use eBay and google for images, facelift is usually bumpers and lights it's in the front end where the wings and bonnet are different as the head light are shaped differently
If they fit, the wiring will be the next issue
