Yarris (vitz) making weird sound
guffo
Strange sound comes and goes in the engine. Its like a whirring sound which will start high pitched and then go lower and lower
Mechanic thought it was a water pump issue, so had it replaced then but no luck!!!
Here is a link to the sound
https://www.youtube.com/watch?v=RN1HVDQpqJQ&feature=youtu.be
Any thoughts are much appreciated
Video unavailable
This video is private.
I think you need to change privacy settings in youtube.
Take the serpentine belt off, start the engine, if sound goes, its something the belt drives, if not, probably engine. Don't leave the engine running too long with the belt off, it may overheat.
That's either the water pump or alternator, if the belts is over tightened it can kill the alternator bearings,  take the belt of and feel is there is any play in the bearings
yep that's alternator whine - remove plug (2/3 pin plug) from the alternator and it should go away - then plug it back in
