Swap Fog Light over for Yaris export?
Yarmac
Anyone know how to reverse / swap the rear fog light & reversing light? (so the fog light is on the left hand side).
Just had a Controle Technique (French M.O.T) & this is the only thing stopping it passing.
I had a look online but can't find anything.
Hoping it's a "simple" wiring issue & a red bulb in the left hand side, but as I say ...that's hoping ;-)
Greatly appreciate any help with this.
The LHD cars use a different body loom, it should be a matter of extending it, It uses a common ground so only 1 wire from each side needs to be swapped
