difference between 48710-05090 and 48710-72010
Inf
Can anyone tell me the difference between these 2 parts? they look exacly the same and are both usable on my auris TS hybrid? but one cost twice as much as the other
About 67000 digits 😋
48710-05090 shows up as (L)
48710-72010 shows up as (J)
There both RHR suspension arms:
48710-05090 is for UK production ( Chassis number starting SB... ) listed as (L) which is local
48710-72010 is Japan production ( Chassis number starting JT... ) listed as (J) for Japan
UK RRP for either is £138.72 + vat
Which one are you finding more expensive?
so the thing is that i need both, right and left arm, are the codes different the R side and L side?
yes there the same number for each side, the difference is where the part is manufactured (L) is Eastern Europe (J) is Japan (as listed in the Abb)
Edit. is the ball joint or the bush that has failed ? Febest list the bushes (TAB-525) - complete aftermarket arm is about 30 euro
Click on the image below to enlarge
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
