headlight replacement- help
AT.
10 hours ago, AT. said:
The item ships from China. Its possible to buy similar from EU suppliers at a similar price - might be quicker delivery.
None of these H1/H7 etc LED bulbs are E-marked and therefore they are not approved for road use. They will work of course - but beam pattern may not be quite correct. In the UK the MoT tester is likely to pass them if the beam is within limits - other countries might be more strict (e.g. TUV in Germany).
