Estima 09 has a constant beep
Hi
Hoping I can get a solution to this problem.
Left lights on the estima which resulted in a flat Battery
There is now a constant bleep sound from around the steering wheel area when driving and when vehicle is switched off. Thank you in advance
Try disconnecting the Battery for ten minutes to see if it resets itself.
Just attempted that but no luck.
Will try if a diagnostic kit finds fault tomorrow
Good luck hope you get it sorted.
