2015 front judder
Hank123
Hi have a 2015 proace and have an awful judder on front feels like its swaying from left to right when I put a little pressure on the accelerator if I ease of it subsides getting to be pain in the ***** garage not sure said replace drive shafts any one else had same problem
Judder when applying power is usually down to driveshaft CV joints. Should be fairly easy to check...
Just had passenger side changed no difference and 200 quid down garage going to change drivers side  next £250 ish garage seem to think it's the flywheel ?? Cant see how myself surely would feel it through pedal
I have similar problems and suspect the engine/transmission mounts, currently investigating. Check the flywheel too and mounts.
Good luck.
