Cold Starting issue. Toyota avensis d4d 2.0 diesel (2006)
Please see the video of my car with cold starting issues. When cold (mornings) the car is very difficult to start 15 to 20 tries at least before the engine firesup.
Once started it will run perfect. Rest of the day it usually starts 1st time.
 Recently one of the mechanic have changed the Battery, test glow plugs and changed all and changed fuel filter but the problem persists. There are no fault codes on the computer.
Any suggestions??
 Recently one of the mechanic have changed the battery, test glow plugs and changed all and changed fuel filter but the problem persists. There are no fault codes on the computer.
Any suggestions??
SCV suction control valve replace now i had this problem until i got in touch w my friend whos a mastertech and ge said its this apparently too there was a TSB from toyota for this issue get yur part number iff your old SCV on the high pressure pump look them up on eBay i paid 55 n my car atarts in minus 5 now no problem before i was same as you maybe 10 to 15 attemps to no avail now it starts like ut did when it was new
